Home Page Forums Articles Videos Search Register Advertise
Go Back   Practical Machinist - Largest Manufacturing Technology Forum on the Web > Specific Machine Forums > Monarch Lathes
Monarch Lathes Discuss 10ee drive types, retrofits, problems plus other Monarch lathes
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 06-30-2010, 08:32 AM
Default Monarch Series 80
We have a Monarch Series 80 Heavy Duty Tracer Lathe, that will not run
in reverse, it seems there is a problem in the switching valve on the hydraulic
pump unit under the main motor.
Does anyone have any idea how to fix/replace this unit.
  #2 (permalink)
Old 06-30-2010, 12:56 PM
Hot Rolled
The hydraulics on these lathe are tricky. I would call Monarch lathe, and see if they can suggest anything over the phone. They use to have a trouble shooting guide on these machines, and they should give you somethings to check out. Its worth the phone call at least.
John
  #3 (permalink)
Old 06-30-2010, 01:27 PM
Thank Ya !
  #4 (permalink)
Old 06-30-2010, 02:50 PM
Stainless
Ran these and series 91. The manual will have a trouble shooting list to go over to help.Nice machines.
looks like one of the lathes from that textile auction a month ago.
  #5 (permalink)
Old 06-30-2010, 02:54 PM
Stainless
You need to stop the lathe motor and then restart it to run reverse I believe.
  #6 (permalink)
Old 07-02-2010, 04:58 AM
We have had this lathe for several years. I took the valve on the pump apart and cleaned
the little slider valves and it worked for a while than quit again ! I thought maybe there would be a way to shim something up or something like that to make it work better ?
  #7 (permalink)
Old 07-02-2010, 09:07 AM
Hot Rolled
The hyd. parts in the dyna-shift headstocks on the Series 62, 80/81 and 90/91 were Monarch's invention. The made nearly everything including the valves and other control devices. Over time these items wear and need to be replaced. About the only way to get these parts is through Monarch Lathe or reverse engineer it or find a similar lathe being parted out. These are great lathes when they run, but can be very expensive to fix.
As I mentioned before, start with Monarch Lathe and see what help they can provid, and then go from there.
John
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Ad Management plugin by RedTyger
