Hobbytools4you
- Aug 18, 2009
- Knowsley, Victoria, Australia
Gidday there, I am new to this forum and need a bit of help with my inquiries into setting up my monarch lathe. Its a 10EE. It is currently set up for for 3 phase. I have an inverter and wish to convert that to 240 volts.
There is a wiring diagram behind the door at the end of the lathe, but is very hard to see. is there a way to change the wiring to star delta? It would be great if someone out there could point me in the right direction. If someone can, I can then give you more info on the lathe an maybe post some pics as to where everything is. Thanks, mark
