Jon Doell
- Jan 23, 2012
- Wichita, KS
Has anyone reproduced the carriage drive gear for a Round Dial 10ee? I don't know how many models take the same gear but I would guess quite a few. I am needing one and was about to get a quote on a gear cutter to make one but if someone made a few I would rather buy than make. Just to clarify I am talking about the gear sticking out the back of the carriage apron that engages the rack. Apparently the rack teeth are quite hard and the spur gear is softer because the rack teeth look like new but the gear not so much. Mine is a 1945 Round Dial and the gear in question has 15 teeth. Outer diameter (tooth to tooth) is approx. 1.28". The root diameter is approx. .954". Also if the exact specs for this gear are known that info would be helpful to get the cutter quoted.
