mathamattox
- Nov 1, 2009
- Charlotte, NC
I need to replace all of the bearings in the taper attachment of my 16CY lathe. The two types of bearings have the following part numbers and dimensions:
- 5201 on inner race, 55501 on metal shield, measures 12mm ID x 32mm OD x 10mm Thick
- 3201 on inner race, 77501 on metal shield, measures 12mm ID x 32mm OD x 15.9mm Thick
The 5201 seems to translate to a 6201 in standard nomenclature, which is a single row ball bearing. The 3201 seems to match the standard nomenclature already for a two row ball bearing.
I saw "77" listed as a code for double shielded in ND nomenclature. Not sure about the "501" or the "55".
I would like to replace these two types of bearings with comparable double sealed bearings but I wanted to understand all of the codes before I make a selection. I am especially curious if there is an ABEC rating that I need to look for. I thought an ABEC 3 would be appropriate for this application.
Can anybody comment if I'm on the right path?
