rakort
Hot Rolled
- Apr 27, 2011
- Central Wisconsin
So questions from a 10EE newb! So wondering what the the attachment rod between the taper attachment and the bed looks like? Green circle? Anything to do with the taper attachment or more like a cutting fluid pipe holding bracket? The red line to the funk covered hole may suggest that is what the bracket is for....but then again that doesn't make sense because the rod needs to attach to the other part of the taper attachment. Anyhow, this setup doesn't seem similar to other pictures I have been able to locate so far.
