John.t.little1
- Oct 10, 2014
- St. Augustine, FL
When I purchased my model 60/61 I knew the power feed didn't work and I wasn't told why when or how. I'm finally ready to fix it. I started by taking the bracket off the right side of the lathe that the rods rest in. clutch rod and feed rod came out simply I wasn't aware of the nut on the backside of the lead screw until reading a post by beckley on another apron removal thread that took the longest Bc the nut was fine threads and in a tight spot. After removing the nut I removed the leadscrew and threading dial. Next was the four* bolts holding the apron. I say four because I have four going down and it took me a few minutes to find the other four came from underneath. So I put two of the bolts back in ontop and removed the other four. I used a ATV jack underneath the apron held it up with a little bit of pressure and looses the last two bolts until they were free. I then lowered the jack enough to clear the gears and moved the apron to a work bench. After a quick wipe down getting all the loose crud off I started to remove the gearing I took a big peice of cardboard like what comes between plywood and layed the parts out on it writing next to it the corresponding location order and part number from the monarch parts catalog. I've taken things apart before and failed to remember exactly how to put them back so figured this would help. Now to the cause of this power feed issue gear 44 and 49 mesh together and provide you with your "power feed" I could see the teeth gone as soon as I lowered the apron but got a better look at them when they were removed. Apparently this has happened before because this set of gears has been molested. Previous owner had taken and turned the gears down to a shaft and pressed on a new gear welded it and called it good. I think I will do the same but use diffrent metal when I make the gear as the metal he used seems to be soft and almost gummy. My main purpose of this post is to ask how you guys would handle this? I would love to have the $3,000 to just buy the gears from monarch. But I've been on the stale bread and ramen diet for some time. I have a dividing head and I have a mill I could in theory make the new gears. I could also buy gear blanks and machine the center out to press in the old shaft weld and they be as previous repaired. Thoughts? Thanks -John
