daryl bane
Titanium
- Mar 12, 2002
- East Texas
After the last installment, the ELSR press to check switch was faulty. Cleared this up and machine ran perfectly. I have not run the machine since this. I fired it up today and machine runs rough, rpm at about 400, but won't adjust slower, can go higher. Looked at C16js while running and LH tube goes dark. Took apart previous faulty switch and cleaned contacts, thinking an odd coincidence with a proven suspect, switch ohms out correctly, no change. Then replaced tube will known tested spare with same result, same with 6N7 just cause. Attached meter to GA2 and S1 to do electronic unit setup. Still reading 75vdc with all pots to zero, which is just not right. Unit runs in forward and reverse, but rough and LH tube goes dark. Not a happy camper right now.
