mike.thomas1
- Mar 24, 2015
So for giggles I went to look at a 1936 CW 16 lathe. Decent looking machine but I have some question about a couple issues that I encountered. The right most gear select lever at first kept me in gear as I went through the speeds. As I operated it a bit more I found I had to push it right/towards the tailstock beyond the detent. Not wanting to open the headstock on the day I just noted it. Is there something that can be adjusted or is there something worn on a shift fork? Second issue I encountered was the feed/lead selection lever did not want to stay in its positions as he used a large rubber o-ring. Whats strange is that there is no detent designed into the selector, but i notice them in later machines. The machine could probably had for a song as it would be bundled with a index milling machine. What should I consider at fault, or should i just pass on this big ol beast?
