Home Page Forums Articles Videos Search Register Advertise
Go Back   Practical Machinist - Largest Manufacturing Technology Forum on the Web > Specific Machine Forums > Monarch Lathes
Monarch Lathes Discuss 10ee drive types, retrofits, problems plus other Monarch lathes
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 06-25-2010, 10:05 AM
Default Resistor source needed for DC panel
Hi, Been searching but cann't find the resistors for the 3 resistor DC panel.
Mine is a 1951 M/G. One 1600 ohm resistor has failed.
Looking for a source and part numbers for the (2) 1600 ohm and (1) 2000 ohm.
Even had a spare panel but it is the one with no resistors.
My machine had the same problem that Gunshack had,chattering DC contactors.
Milton C.
  #2 (permalink)
Old 06-25-2010, 12:44 PM
rke[pler's Avatar
Titanium
It always looked like an Ohmite resistor, maybe one of the 270 series?
  #3 (permalink)
Old 06-25-2010, 03:17 PM
peterh5322's Avatar
Ohmite is still in business, although only a very small fraction of its former self is available from stock.
  #4 (permalink)
Old 06-25-2010, 04:04 PM
Cast Iron
If you have the Ohmite part number, that's a good start.
If you know the wattage and the resistance, that might be better.
Once you determine some details, go shopping on ebay.
  #5 (permalink)
Old 06-29-2010, 06:22 AM
Hot Rolled
Newark Electronics carries Ohmite. I have purchased replacement resistors for 10EEs from them in the past.
1600Ω isn't a standard value, but 1500Ω is, and works just fine. IIRC, those are 50 Watt resistors?
1500Ω/50W--Ohmite p/n L50J1K5E---Newark p/n 64K4992 $8.99 ea.
2000Ω/50W--Ohmite p/n L50J2K0E---Newark p/n 64K5003 $6.75 ea.
http://www.newark.com
  #6 (permalink)
Old 06-29-2010, 09:40 AM
peterh5322's Avatar
If there were space available, a 1500 and a 100 ohm resistor could be placed in series connection.
Also, a 2000 ohm adjustable resistor could have its tap set on 1600 ohms.
  #7 (permalink)
Old 06-29-2010, 04:16 PM
Default Resistors for 10EE
Thanks for the help.
Will get order together & report back.
Milton C.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Ad Management plugin by RedTyger
