catman60957
- Jan 9, 2004
- Paxton, Illinois USA
I've replaced the cross slide screw and nut, new thrust bearings in the CS and compound and got the taper attachment freed up and cleaned. I'm taking the carriage off to clean the oil passages and I'd like to take the apron off to clean inside and replace the oil pump O-rings. Now I'm pretty sure the carriage removel is a straight forward job, but the apron I'm not so sure. I would imagian the feed rod/lead screw brkt on the tail stock end of the lathe will have to come off. But I don't know if the feed rod/lead screw just slide out of the gear box or not. Then theres taking the front off of the apron, is anything part wise going to jump out or will every thing stay put? If anyone has been thru before this I could use some guidance on procedure. Thanks for any advice.
