Monarch square dial 1/2 speed
Flightmap
Oct 28, 2013
San Diego, CA
My 1963 10ee was working fine until the other day. I warmed it up and then engaged the spindle lever prepatory to turning the speed control. The machine powered up to 4000 rpm immediately. Since I almost always power the machine down with the speed control set to zero, this surprised me. I immediately backed the speed down to zero.
i ran the lathe for about three hours and couldn’t get it to run faster than 1200 RPM (indicated), but it responded to settings below this number. Remembering that the pot was dual stacked, I figured it was OK to run that day.
i checked with a member here and he suggested I look at the diodes on my machine for the lack of upper end speed.
My question: does anyone have a list of diode conversion numbers/mfg’s for all the diodes?
according to another post here, there is a issue with the brackets for alternate diodes. What is the work-around for this?
if you have dealt with this problem, would you suggest I just ask Monarch for a complete array of diodes and replace, Or, look into alternative diodes and brackets? $$$ not with standing
thanks in advance, Ken
On the inside of your module box cover should be a map of the diodes, here is a picture of mine
Shared album - Module Map
This shows the polarity of the diodes, they are flipped around at random. There is no issue with the brackets, they have polarity and the diodes must be installed in the correct orientation. The brackets that hold the diodes have guides that may not be easy to see, but pull a diode out and flip it and put it back in and you will see how the diode no longer fits in it's bracket.
Shared album - Module Box
The Monarch diodes are old school electronics and there are better versions available today for cheap, but you will either need to machine end pieces to fit the brackets, or just solder the diodes directly to the brackets.
I forget what the rating of the recommended replacement diode is, maybe 1 or 2 amps, very common parts, search the archives.
There is also a photo of a module that has lived a hard life. It has a few soldered diodes. Note the burn marks on the diagram that correspond to the replaced diodes.
While you have the module out, check (and record) the resistance between the terminals of the potentiometers.
You can also loosen them and check the resistance of the terminals over the range of the pot.
It is always a good idea to swap with a good C3J replacement tube when troubleshooting a modular.
And you can always buy a refurbished module box from Monarch, they are only $2000.
Here is a photo of a module that has lived a hard life. It has a few soldered resistors. Note the burn marks on the diagram that correspond to the replaced diodes.
Shared album - Module Box 2
I also think your module is probably repairable.
If you end up needing to replace the module, one of the forum members recently designed and is selling a replacement for the module.
For Monarch 1ee Lathe
Ryan
I have made replacement diode assemblies for several machines.
I used 1N5408 3A 800 PIV diodes. The package has a larger dia. lead and a longer package than a 1N4004
Lots available on ebay for less than 20 cents each for 10 to 20 Pcs. and free shipping.
There were a couple of threads in this forum covering the construction of these.
OK. But I think OP's real question is whether or not his speed control problem is due to a diode issue or something else. Anyone?
Cal
Cal
Yeah, I've had the same problem twice. Once it was because oil had fouled the speed control pot. The second time was because the C3J tube had burned out. Why do you think this is a diode problem?
Yes, adh2000. I don’t know that it is a diode problem, but from the posts I read, it seemed logical. As stated, i know nothing of electricity, so I read what others say and try to draw my own conclusions (not the best, but it is a start)
i Looked in the other compartment at the three tubes, and couldn’t see any visible problem with any of the tubes. Based on several comments on polarity, and potential shorts, I didn’t test them.
regarding the speed control pot: I’ll Take the back cover off (need to do this for another problem anyway) and see if I have any excess oil around the speed potentiometer. Don’t remember seeing the back of the pot in the cavity, but will look again.
to all above, thanks for taking the time to read and comment. Aside from Monarch’s ability to replace the “black box” is there a recommendation for someone who has designed a replacement for the box or diode rack (either or both) that is a simple install? The site titled SSE(?} (I think this was Ryan’s suggestion) mentioned above may be more than I can handle. I’ll ask them Monday, but it may be beyond my ability or comfort range.
again, my thanks for all the responses
Ken
The speed control pot should be inside a cast iron housing just below the right side main spindle belt tensioner.
The module pretty much plugs in and out, there is a thumbscrew that holds it in. You can remove your module, clip a few wires and ship to Scissio and they will do minor surgery on it for you. Then you just plug the new one in. Read the pdf at Scissio site for instructions.
Spindle module replacement complete
This is what I was looking for regarding the diode replacement issue and didn’t realize when I read Ryan’s post, what they were talking about.
Now that I have a potential solution, I’ll focus on the other possible causes of my problems. Thanks to you all for you time and thoughts
Start by pulling the module,power up and start spindle.
The spindle will run but not have any speed adjustment, at about 2000 RPM.
Let us know what you have found.
Bill
Cal
I have no idea if it's a diode problem or not, hence the question. I don't know much about 10EE tube drives, but I recall that modular-drive machines have problems with diodes. OP contacted me off-line, so I sent him here for a solution.
Cal
