Round Dial Rheostat Measurements - Test - Etc - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21
    Sep 2002
    Arizona
    3,277
    616
    362
    OK, so three or four sections of approximately equal length in the varying resistance zones, right?
    If it's not too much trouble, a resistance measurement across 10 turns in each section would be nice to have.
    Cal
  2. #22
    Apr 2011
    Wisconsin
    100
    22
    10
    Quote Originally Posted by Cal Haines View Post
    Cal
    Yes, exactly.
    I'll see about getting readings on a couple of turns.
  3. #23
    18,747
    7561
    5920
    Quote Originally Posted by rakort View Post
    Yes, exactly.
    "Tip". Literally. The old RCA VoltOhmist VTVM has probes that used Victrola-era ground steel "phonograph needles" in a collet-clutch.
    Helps to have that precise a contact when vetting low-Ohmage wirewounds.
    Few modern probes have that, as the buggers will draw-blood or slice tissue just as easily as pierce insulation, surface coatings, or corrosion!
