Zahnrad Kopf
- Apr 5, 2010
- Tropic of Milwaukee
Greetings All,
While cleaning up parts, I discovered some inconsistencies with my Stop Lever. After some reading and examination, I believe what I have is incomplete and modified to boot, And so will want to replace it and the missing parts.
In my manual ( '42 Round Dial ) they are parts E-14, 47, 48, 62, & 63. The Stop Block, Stop bushing, Stop Bushing ( same ), and Stop Lever.
First, my lever and "bushing" are on the left of the carriage, which I believe to be incorrect if I am understanding the bushing's operation. As well, I believe my lever and bushing have been modified and no longer function as intended. This can be remedied with some work or the purchase of replacements, but I am also missing completely the opposite side's Stop Block and Stop Bushing.
All of these parts are easily made if one gives little to no regard for the original's aesthetics. They can be made simply enough from round stock and function all the same. The problem lies in the fact that I like the look of the originals...
So, before I cut the handle off my old one in effort to silver braze it onto a new one, does anyone have these parts that they might part with?
Also, in the case that I make them, can anyone tell me what size the real ones are threaded?
Is my understanding of them correct in that they function with the feed rod to affect a spindle stop ( eventually ) for use with threading and feeding up to a shoulder, or what have you?
Thanks.
Thanks.
