brushpile90
- Jul 8, 2014
- Huntington, Indiana
I just purchased a used 2a-d3 chuck and mounted in this afternoon and had about .0025 runout less than an inch from the collet. I then indicated the collet taper and showed roughly the same. I disassembled the chuck and it is basically two halves, one with the d1-3 taper and one with the collet taper. They mesh up right where the handwheel is. I mounted half of the chuck on the lathe and still have the runout issues. The Monarch spindle has no runout, the sjogren chuck has .003 runout radially directly where it meets the lathe spindle. There is also runout on the face of this half of the chuck, where the other half bolts on.
The d1-3 mount had no interference and would just fall off when the cams were loosened.
I marked the face of this half for the high spot and the low spot, chucked it in another lathe so the d1-3 face (opposite where I marked) could be cut. I indicated it and the high spot was still high and the low was still low. I took a skim facing cut, just enough that it would cut all the way around. I'm guessing about .002 on the high side to .0005 on the low side. I then remounted it and now have some interference with the D1-3 taper. It mounts, snugs up and takes a nice pull to get it to come off. I do not think there there is a gap on the D1-3 face.
I still have runout on the face (and radially) of this half of the chuck. My question is should I try to correct the runout on the D1-3 mounting side, or is it safe to take a light facing cut on the face of the chuck that mates to the other half? I am concerned that even if I reface this surface, the other aligning parts may still be off? I have not touched the actual D1-3 taper and am afraid to do that. If I take any more off the face portion of the D1-3 I will most likely have to address the taper in order to get a flush fit.
I was hoping for .0005 runout or less with this chuck. Very disappointing.
