gpcoe
- Nov 21, 2009
- Bennington, NH USA
What should have been a leisurely move turned to disaster. I borrowed some machinery skates from work and successfully moved it into position. I had moved it to remove the generator. I had also removed the motor as well. I decided to move it back so I'd have better access to the motor cavity and when I jacked up the spindle side to take it off the skates it didn't lift evenly. I had the lifting jack in the middle of the casting where I've lifted from several times before so I didn't think much about it, but I failed to realize that because all of the motor and generator were removed that the lathe was now extremely top heavy. Before I could make the decision to drop the lathe back down to move the jack, the CG shifted and the whole lathe toppled forward.
NOBODY was hurt!!! Just my pride.
Long story short, a good friend brought over a chain hoist that we strapped to the roof joists and we were able to get it upright again. I'll post pics of the up righting when he emails me the pictures. Anyhow, most of the damage seems to be centralized on the front control knobs, and the tail of the direction control (this is a ELSR machine) was broken off. I'll need to make a new rod and tail peice.
The most concerning is that cross slide leads screw no longer turns smoothly. I won't know til I can dismantle it, but I fear that it may be damaged. Do I remember right that someone was making a new replacement leadscrew? Anybody have some info on this?
Anyway that's all for now.
Greg
