The previous owner of my basket case square dial did some really questionable things, probably because he didn't have access to this forum. While (or possibly after) attempting to remove the gearbox, he tried (without success) to remove the right cover from the gearbox. In the process, he slightly bent it while prying on the lower front corner.
I made the poor assumption that re-installing the SHCS and tightening them really well would seal it well enough. After all they are nicely machined surfaces. Wrong! When I installed the gearbox and filled it with oil, I found a puddle of oil on the floor the next morning, obviously from the cover. It only stopped when all the oil had drained out -- roughly a quart of expensive oil.
I have now removed the gearbox with the intent of properly removing the right cover and then making it seal properly. Certainly some Hylomar Blue, and maybe a thin gasket. What do you think?
The big question now is whether or not I can remove the right cover without doing a complete disassembly of the gearbox. Does anyone know if it can be done? If anyone has done it, I would appreciate any hints you can give me.
Alan
Alan
