Question about the little upper bearings on the countershaft in the backgear gearbox. The bearings in mine, not original, were New Departure 3203. I replaced them with SKF 203. These bearings are identical, 17x40x12. However, when reassembling my gearbox, when I have proper spacing for the shaft the front bearing is too far forward in the front casting and the bearing cap will not tighten down on the paper gasket, and that is with the rear bearing sticking out the backplate the thickness of the paper gasket and rubbing the motor front plate, which I am not really comfortable with. All gaskets are new and from Monarch. The lathe is functional, but oil leaks out from underneath the bearing cap since it is not tight to the casting.
when I disassembled the gearbox originally there was no gasket under the bearing cap, only worthless silicone.
I disassembled the gearbox and have been pondering the pieces and checking clearances for the last 2 hours.
The only conclusion I can come to is the bearings are not the proper ones. The bearings in the flat belt idler have an inner race that is slightly recessed (0.025") to the outer race on one side and is the same OD as these in the backgear gearbox, so now I am thinking that the original bearings were some special New Departure type that had the inner race recessed slightly as well. The bearings in the pulley are doubly weird in that the inner race protrudes from the outer race on the other side, so that bearing type can't be used. If I had an extra 0.025" clearance both front and back I would have a much better installation.
Does anyone know positively what the original countershaft bearings were on a WIAD type gearbox?
