chipkid
- Mar 7, 2015
- Eastern PA
Wicked excited about a 10EE find !!
Thanks to the PM buy/sell forum...I found a 10EE !!
Very appreciative to all who reached out.
With a special thanks to Marc.
Here are some specs:
1969 Modular Machine
4000 rpm 5HP 3 phase 240V
Serial No 50007
Built 4-1969
Options and included tooling:
ELSR Machine
Taper attachment(missing the way mounted support for the guide rod)
Dial indicator on the carriage
Aloris AXA tool post(wish it was a BXA)
Coolant pump (probably won't use it)
8 inch 3 Jaw Buck Chuck (big chuck I may look for a 5 or 6 inch)
Sjogren 2J speed Chuck
10 3/4 inch faceplate
Precision German tailstock drill chuck
Original Monarch wrench for the carriage lock
Has work light but not the original
FWD/STOP/REV lever is on the carriage not the headstock
General Condition
was told it came out of a Honeywell facility in NJ.
Overall a clean machine cosmetically.
No bent or broken control knobs or levers.
Ways look to be very, very clean, no ridge on inside way.
Carriage moves very smoothly
25-30 thou of backlash in the cross slide and compound.
Dials are clean, and turn smoothly
Tailstock is clean and tight, taper is clean
Headstock spins super smooth and quiet.
Issues:
Spindle reaches about 1500 rpm max. When the pot turned to max it hits about 1100 right away and slowly drifts to about 1500 over about a minute then tops out.
In back gear it reaches just under 1000rpm if memory serves me.
The gearbox has little or no oil in it, must be leaking (motor compartment is oily) and it may have migrated into the dual pot.
Good news...The headstock is full of oil.
I don't know if the oiling system is working for the carriage.
Next Steps:
Get it into the shop. This will take a week or two, due to my schedule coming up. Then troubleshoot the Modular drive system components. I am anticipating some tube an diode trouble...Maybe brushes, and maybe a dual armature/field pot. We shall see. I have a schematic for a 65, but I may need to order the manual and schematic from Monarch for my machine.
Anyway, I am very excited to get her up and running and making some chips ! This thing makes my Heavy 10 look like a toy. I will get pics up as soon as I am able. Looking forward to sharing this project in the forum here.
Serial No 50007
Built 4-1969
ELSR Machine
General Condition
Issues:
Next Steps:
