Say you want to plumb robot spot welder gun for the open and close of it's electrodes (accomplished via double acting air cylinder), is it typical for the air output for open and close, to be done with one air solenoid with "double solenoid, center off position" (3 postion directional control valve with exhaust ports)...or more typical to be done with two "spring return to off" type solenoids (2 position valve with exhaust port) ?
My impression, from looking at fuzzy photos of robots, is that it's more typical to use two (2 position) valves mouned on a common manifold.... but if so, I wonder why, as it seems like one 3 position valve would be simplier.
