metron9
- Oct 29, 2009
- Minnesota U.S.A.
I have a machine I have had to replace this gear unit on three times now'
The brass gear that rides on the worm gear just gets pummeled.
If the gear unit is rated at 527 lbs torque, How much weight can it lift, or should it lift. The cam rides on a 1.5 inch ball bearing.
I plan to add air cylinders on each side of the head this cam is lifting so I won't have to replace it again.
