Tonytn36
- Dec 23, 2007
- Southeastern US
For those who program and set up robots, it can be a PITA to determine what the motion limits for each axis should be set to.
Attached is an small PC program for a Kawasaki D controller that will determine the maximum and minimum motion position for each of the 6 axis.
I had to change the file extension from *.pg to *.txt in order to post it, so just rename it after download.
To use:
1. Load program as a PC program and execute in endless loop mode (-1).
2. Run your motion program, including any branches and at the maximum limits if variable positions are used.
3. Using KCWin on a laptop or the keyboard on the teach pendant, use the following commands:
list /l #liml <enter>
list /l #limu <enter>
The minimum motion limit for each axis will be stored in variable #liml.
The maximum motion limit for each axis will be stored in variable #limu.
I have no idea if this will work with other controller manufacturers.
To use:
