The Dude
Hot Rolled
- Oct 19, 2010
- Portland, OR
We are re-purposing a piece of used equipment we purchased (very cheap). It has a DC shunt motor, 115 volts, 1/50 HP (0.33 amps). The OEM power supply is bad (no DC output)and obsolete and it's also likely that we won't need variable speed. I'm trying to determine if I can power the motor at it's rated RPM (1725) with just a plain DC power supply (ideally 115 volts). I've checked Minarik, Automation Direct and they don't make anything less than about 1 AMP for a variable speed power supply. If I find a DC power supply at the rated voltage it looks like I can just wire up the shunt and windings off of the same voltage, is that correct?
The Dude
The Dude
