Gripping 5 mm acrylic rod in confined space
Results 1 to 3 of 3
    Feb 2017
    25
    5
    9
    Default Gripping 5 mm acrylic rod in confined space
    I am using bushing and 2 set screws to hold a 5mm acrylic rod. and right now the set screws are causing the rod to flex away from the screws by several degrees or two. Do you think a miniature collet like something for handheld tool would hold the rod closer to straight or am i just going to have issues given a small diameter of a soft material. I have very limited space and mass for the attachment mechanism.
    Yes i am aware acrylic is not the optimal material for this...
    Dec 2007
    Central Ohio USA
    3,411
    19
    1484
    In pro audio/video equipment, there are some nice collet-style control knobs that have a plastic outer body, but a nice brass collet assembly inside, tightened by a screw. They might give you a headstart on a nicely coaxial mount for your acrylic shaft... depending on what you have to affix it to. 5mm seems to be avoided in the link below, but there's a 6mm, and I'll bet you can find a drill somewhere about the shop...
    Classic Collet Knobs
    One example of many out there, revealed in the Google search of: collet mount knobs.
    Chip
    Dec 2004
    uk
    11,975
    3229
    5244
    Google shaft collars, get the split type and you should get no deflection that way.
