Having problems driving a TLY Servo Motor with a PowerFlex40...
Results 1 to 4 of 4
    Apr 2017
    CANADA
    Ontario
    7
    Question Having problems driving a TLY Servo Motor with a PowerFlex40...
    As the title. I've set up the drive to limit voltage to 230V so as not to damage the drive and connected everything up. I expected it to hopefully just work with that but I get an odd jittering of the motor instead while the VFD reports it outputting about 2.5 Hz for maybe half a second then dropping to <0.2 Hz. Really not sure where to go from here.
    The PowerFlex: 22b-e3p0n104
    The Motor: tly-a230t-hk62aa
    Any assistance would be appreciated.
    Dec 2003
    Washington
    4,473
    1980
    3569
    You are very likely over voltaging the motor for a given frequency.
    How many poles does the motor have? What's it's rated speed at 230V?
    Apr 2017
    CANADA
    Ontario
    7
    Quote Originally Posted by motion guru View Post
    It is three phase and rated for 6000 RPM @ 230V
    The VFD operates from zero to 60 Hz and the minimum voltage is 40V. When set at 40V, the motor rotates with some odd grating noises and is jerky to start. Higher voltages just have the motor jittering in one predictable direction and the stop function does work. At 40V it rotates predictably @ 60Hz but becomes erratic just like the higher voltages when the frequency is lowered and also the VFD cannot stop the motor with the panel button, the power must be manually opened to stop the motor.
    Dec 2003
    Washington
    4,473
    1980
    3569
    6000 rpm at 230V . . .
    A pm brushless servo motor rated at 6000 rpm could be 2, 4, 6, or 8 or ??? Poles
    For grins, let's say it is 8 poles. Hz = RPM x # of poles / 120
    6000x8/120 = 400Hz . . . Enter name plate data of 230V at 400Hz and see how that goes. You really need to know the number of poles to get the flux density set correctly.
