Denny Graham
- Sep 1, 2004
- Sandwich, IL
Many many years ago I saw a dragster that used two small single action hydraulic cylinders of the same
bore for a throttle control. It was a real simple setup, all very low pressure as the cylinders simply
acted as a solid link between the pedal and injectors. There is was no multiplication of force simply one
small cylinder moving another of the same bore. If I remember one of them or maybe both had a compression return spring in it/them.
I'm building a Cyclekart with a 6.5 hp Honda GX-200 engine and would like to use a hydraulic link to the
throttle instead of the typical rod/cable or wire such as used on gokarts.
The part that has me in a tizzy is the O'-ring seal. the bore can be quite small such as .5" and the wall of the cylinder doesn't have to be thick because there is no pressure to speak of. I'm thinking a steel shaft fitted with an O-ring and O-ring seals at the end that has the assembly nut.
I'm drawing a blank as to the O-ring grove and clearances. The cylinder will probably be aluminum honed
to the correct size so the O-ring will seal.
Any Ideas or experience would be more than welcome.
Denny Graham
Sandwich, IL
Denny Graham
Sandwich, IL
