part counting
Results 1 to 7 of 7
Thread: part counting
    Jan 2018
    Missouri
    5
    Default part counting
    Looking for a solution. We have small parts that do not have much weight to them. We need to accurately count them for bagging. We have tried to use a scale and tare it out to do a regular part count. Not accurate, parts are too small for the scales we have. Looking more for detection equipment. Not sure because of the weight if anything but laser would work. What type of automation is recommended? Thanks for your time.
    Oct 2005
    erie,pa
    8,977
    16021
    4551
    How many different parts ?
    can you simply Polk Yolk it with some boards with holes in them ?
    slide a handfull across the board, only 1 can occupy each hole,
    shake off the excess.
    Mar 2011
    Denver, CO USA
    10,480
    38
    4459
    ^^^^good thought.
    How about a vibe feeder and correct scale?
    A vibe feeder and a optical sensor works.
    How small are the parts, what shape?
    Feb 2013
    Madison, WI
    626
    831
    375
    How much are you willing to spend? A quick google search popped these up.
    Coleman Technologies- Turnkey Measurement and Control Solutions
    tabletop counters for counting small parts
    Nov 2013
    NW Oregon
    49
    28
    Quote Originally Posted by tracystrehl View Post
    What type of scale were you using? We have scales in use that have a .0001 gram resolution. Those will accurately count #2 set screws, and probably smaller.
  6. Likes [email protected] liked this post
    May 2004
    Paradise, Ca
    2,008
    558
    950
    Is the size, shape and weight of the parts a secret? Material the parts are made out of? What kind of quantity are we talking here? 50 per day? 3,000 per day? Are they coming in on a conveyor? By the handful?
  8. Likes digger doug liked this post
  9. #7
    Mar 2017
    42
    15
    15
    Check out AnD at the link below. It has save us hundreds of man-hours dealing with micro sized parts.
    FX-2I | A&D Weighing
    If the parts exist, this will weigh and count them accurately. We weigh some pieces of .030" OD/.017" hypo tubing with ours and it works well. You need to shield the balance from wind in the room for most accuracy.
