part counting
Results 1 to 9 of 9
Thread: part counting
    Jan 2018
    Missouri
    5
    Default part counting
    Looking for a solution. We have small parts that do not have much weight to them. We need to accurately count them for bagging. We have tried to use a scale and tare it out to do a regular part count. Not accurate, parts are too small for the scales we have. Looking more for detection equipment. Not sure because of the weight if anything but laser would work. What type of automation is recommended? Thanks for your time.
    Oct 2005
    9,848
    16997
    5072
    How many different parts ?
    can you simply Polk Yolk it with some boards with holes in them ?
    slide a handfull across the board, only 1 can occupy each hole,
    shake off the excess.
    Mar 2011
    Denver, CO USA
    11,159
    41
    4960
    ^^^^good thought.
    How about a vibe feeder and correct scale?
    A vibe feeder and a optical sensor works.
    How small are the parts, what shape?
    Feb 2013
    Madison, WI
    692
    897
    446
    How much are you willing to spend? A quick google search popped these up.
    Coleman Technologies- Turnkey Measurement and Control Solutions
    tabletop counters for counting small parts
    Nov 2013
    NW Oregon
    49
    29
    Quote Originally Posted by tracystrehl View Post
    What type of scale were you using? We have scales in use that have a .0001 gram resolution. Those will accurately count #2 set screws, and probably smaller.
  6. Likes [email protected], sfriedberg liked this post
    May 2004
    Paradise, Ca
    2,110
    612
    1030
    Is the size, shape and weight of the parts a secret? Material the parts are made out of? What kind of quantity are we talking here? 50 per day? 3,000 per day? Are they coming in on a conveyor? By the handful?
  8. Likes digger doug liked this post
  9. #7
    Mar 2017
    51
    19
    21
    Check out AnD at the link below. It has save us hundreds of man-hours dealing with micro sized parts.
    FX-2I | A&D Weighing
    If the parts exist, this will weigh and count them accurately. We weigh some pieces of .030" OD/.017" hypo tubing with ours and it works well. You need to shield the balance from wind in the room for most accuracy.
  10. Likes sfriedberg liked this post
  11. #8
    Mar 2018
    It's hard to say without seeing the part/drawing. You might be able to count them with a Cognex camera.
  12. #9
    Jan 2007
    Flushing/Flint, Michigan
    6,324
    259
    5148
    People had to count the number of mini paper cups in a stack at very high speed and weight would not work.
    This was solved before there was a IBM PC.
    All depends on the parts and how the packaging is filled.
    When weight fails due to weight per piece variation and pack size, opto, laser, vision but these need part separation.
    Counting the number of M&Ms flowing into a pack at the fill speed would be hard but this is sold by weight.
    Bob
