I have a customer who makes plastic strips, with sprocket holes, like a film strip.
They currently have a crank driven punch press with the strip fed by a pneumatic feeder.
They are planning to replace the punch press with an electronic punch press, and replace the pneumatic feeder with ...???....
A sprocket drive sounds ideal to keep the registration of the sprocket holes, But how would you start it on a new roll? It couldn't feed the part until it had sprocket holes ...
Catch 22, chicken and egg...
They make different products, and switch the lines over to different sizes...
An electronic linear drive for the feeder would be great, they need to adjust the feed to a couple thousands, ( .05 mm ) or less.
A drive roll (friction drive) might be best, can we expect that sort of accuracy?
They currently adjust the pneumatic feeder with a set screw..
So, any suggestions for linear feeders, drive rollers, etc?
Looking at a PLC to control this and the downstream/upstream machinery.
Should help out for setup and changeover.
Thanks for any direction for the servo driven linear feeders, or drive rollers, and experience.
