robot arm integration and path motion question.
Results 1 to 3 of 3
    Oct 2003
    East Peoria, IL, USA
    5,228
    289
    687
    Default robot arm integration and path motion question.
    My question is about integrating a standard welding or similar robot within a larger system
    Is there a way to constantly update a vector to a standard weld arm? I want it to follow a path with constant velocity while mounted on an unsteady moving base using laser or similar location feedback.
    I wish to avoid developing an arm and just buy and interface with a standard inexpensive arm then just feed it a constantly updating vector. Is that a possibility with any off-the-shelf controllers?
    Apr 2013
    New York
    754
    624
    606
    A lot of manufacturers have the option to run a 7th axis (or more) through the robot controller. Off the top of my head, I know Fanuc and Denso can both run a 7 axis system without any trouble, and I'm pretty sure Denso robots and controllers can integrate an 8th as well, without any expansions/additions.
    What I don't know is how many axes they can do simultaneously - your best bet is to talk to your robot supplier on this one, because you're talking about a dynamic 8 axis system, and I'm not sure any of the industrial robot manufacturers have an off the shelf solution for this. (A couple of guys here - Tony, MotionGuru - might know differently.)
    If you're talking a 6 axis robot moving dynamically in 2 or more dimensions, don't discount the complexity of finding your relative positions either - a laser sensor for distance is fine, but that only gives you location in one direction, and you'll need it in 2 or more, depending on your system and what it is you're trying to do.
    Are you trying to figure out a 'walking' robotic welder system of some sort? Or do you just want to mount a 6-axis on a 7th that runs at close to the same speed as an adjacent product conveyor?
    If you're getting into robotic welders, definitely take a look at ABB robots. They have a cool system for their weld robots that automatically guide them to follow uneven material, crooked joints, out of square setups, and a couple of other normal situations, all by monitoring the current through the welder. Very tricky stuff
    Dec 2007
    Southeastern US
    6,160
    680
    2513
    Kawasaki offers the option of you feeding it motion command / targets from an external source in basically real time.
  4. Likes dsergison liked this post
