A simple robot thats easy to program.
Results 1 to 15 of 15
    Aug 2010
    Southern California
    31
    13
    Default A simple robot thats easy to program.
    Hey guys.
    I was wondering about a robot for loading and unloading of parts into a lathe.
    Do they make a simple robot arm that has a simple programing language?
    It only needs 3 or 4 axis to swivel and articulate a pre-programmed set of movements.
    Also a "HAND" that closes and opens to hold material.
    Does such a thing exist?
    Or are they all complicated?
    PS: It seems to me that a simple load/unload robot arm could be programmed with Gcode, but im not sure.
    Do you guys have any suggestions?
    What say you?
    Sep 2009
    barcelona, spain
    2,108
    428
    1174
    None exists - afaik.
    Baxter is perhaps nearest at 20k$ or so, plus n, x, y, z, ...
    Grippers, actuators, guardings or rails, certs, integration.
    And industrial robot is about 40k€ wholesale, lathe, 3 kG end-effector mass, and 3x when working.
    About 100k and up.
    I may be working on this ....
    Value is important.
    If You think a 5k all-in, this is unlikely short term, due to industrial legislation.
    If You think 30k total is feasible, then well ....
    You know what to do.
    Mar 2015
    Indiana
    13
    if your motion requirements are highly constrained, then you could cobble together a X-Y-Z system of pneumatic linear actuators and grippers. See Pneumatic, Electric, & Hydraulic Actuators | PHD, Inc. for one of many suppliers of that kind of equipment. But if tilt is needed, then you are probably out of luck.
    Jan 2007
    Flushing/Flint, Michigan
    6,190
    246
    5009
    All robots are easy to program.
    They just speak a different language, early days many did g-code.
    You walk and talk G00, G03, G54, G42, G81 which makes no sense to a common man.
    They are just different but still machine tools.
    Bob
  5. Likes Jashley73 liked this post
    Apr 2014
    IL, USA
    112
    75
    48
    Sawyer Collaborative Robots for Industrial Automation | Rethink Robotics
    Sawyer is the next version of Baxter. It only has one arm and is geared towards loading machines and things like that. Baxter is more suited for packaging type tasks. They are both programmed by physically moving it through the motions you want it to perform.
    Feb 2010
    IN, USA
    182
    7
    196
    Quote Originally Posted by J&H View Post
    It's amazing how much that thing shakes in the video. Watch closely when the gripper tries to pick up the part from the pallet and again when it tries to load it into the chuck.
    Feb 2005
    Akron, OH
    1,569
    215
    1118
    A real industrial 6 axis robot is only $30k new for a one-off with IP67 protection, which you NEED for a machine tender.
    All robots are falling down easy to program for simple pick and place, especially if they are owner operated so you can just jog them out of screw-ups instead of having to code error handling routines.
    Why are we talking about Baxters (a complete joke) and Universal (50-100% overpriced)?
    This application is easy for any robot. Pick one and get at it.
  9. #8
    Apr 2013
    New York
    754
    624
    606
    Quote Originally Posted by Comatose View Post
    This conversation is actually ongoing in a couple of different threads right now.
    With a real, industrial, 6-axis robot, the price of the robot (and controller) are a small part of the total cost of the system. Opinions vary, but the prevailing thought between the automation guys (Tonytn26, Motionguru, and I'll include myself, even though I'm not in their league) is that the total system will cost from 2X (if you do this all day, every day, and have existing designs for the mechanical and controls systems) to as much as 4-5X (for new projects, clean sheet designs, etc.) the cost of the robot, to get a new 6-axis robot integrated properly.
    So a $35,000 robot turns into a $100,000 automation cell, very, very quickly.
  10. Likes Jashley73 liked this post
  11. #9
    Feb 2005
    Akron, OH
    1,569
    215
    1118
    Yes, but how is a universal robot any different? No more than $5k of the integration cost is the cage. What else can you skip with an overpriced collaborative robot?
    I don't disagree that the cost of a well engineered cell is between twice and three times that of just the robot, including labor. But what costs of those does a collaborative robot, which has to be programmed a good bit more carefully to be safe, save?
  12. #10
    Dec 2007
    Southeastern US
    6,160
    680
    2513
    Collaborative robots have serious speed limitations due to the collaborative aspects. Inertia and all that..... Most folks doing industrial stuff won't be keen to taking a very large cut in productivity speed to reduce out a person, it is just not economically feasible in most industries.
  13. Likes Johnny SolidWorks, Amach328 liked this post
  14. #11
    Apr 2014
    IL, USA
    112
    75
    48
    I haven't had any robot experience at all.
    As the business here grows, I'm hoping that I can use one of these collaborative types to limit hiring people. I don't want to set up something to run the same part for years and years. What I'm hoping I'll be able to do is set the thing up to change a couple hundred parts in the lathe, while I set up the next job in another machine, as an example. If it worked 2/3rds the speed of a human, it would still be better than having to run over and change parts myself every 3 minutes, yet it could be monitored without too much trouble. Maybe this isn't practical, or maybe it isn't practical now but maybe it can be as the robots continue to improve.
    If there's no parts to run tomorrow with no real quantity, the robot can sit on the shelf for a couple of days easier than figuring out what to do with an employee for a couple of days. It might not be the total solution, but it sure seems like if something could just tend a machine now and then, it would sure help keep the labor down in a smallish job shop environment.
  15. #12
    Jan 2013
    Louisville, KY
    2,727
    6275
    2258
    Would it make sense to look for an out of the box, pre-packaged system. I don't have any experience with them, but maybe one of the Halter systems would be good for you...? Still considerably more expensive than the robot's price itself, but ready to go?
    HALTER CNC Automation - HALTER CNC Automation | Robotising every brand of CNC machine
  16. #13
    Nov 2012
    Bozeman, Montana
    26
    9
    16
    If you've ever done any computer programming or have some knowledge of logic/flow control concepts(I mean really really basic stuff like loops, if/then, etc.)then you can do a lot very easily with the UR. It also helps if you can wire up relays or pneumatics and use a multimeter. Most of the programming is done by physically moving the robot to various waypoints. Pretty easy. We're in a similar situation where we have products that sell in spurts, then a trickle. The robot and lights out machining lets us buffer those spurts without having to hire and layoff people all the time or deal with temps. So for us a fast cycle time isn't all that important either. We can load up enough stock to let it run for twelve hours when we need it. Some nights we don't run it at all. I actually think robots are ideal for small (even one-man) shops.
  17. Likes Amach328 liked this post
  18. #14
    Apr 2014
    IL, USA
    112
    75
    48
    Here's a video someone posted to Facebook yesterday in a machinist group, showing the exact set up that I'm picturing in my head:
    robot - YouTube
    I have no details on his set up yet, but he's posted other videos of him running the same machine without the robot. Looks like he just shoves it out of the way when he doesn't need it. I believe he's in the UK...
  19. #15
    Oct 2013
    New Jersey
    764
    642
    So think how much money you could save just automating the door, for robot or human! Cycle finish pops the door open while robot or operator is prepping next part. Time savings either way.
