Results 1 to 6 of 6
    Jason H is offline Stainless
    Mar 2006
    Los Angeles, CA.
    1,369
    Default Laser Education - was roll cutter
    Okay, the emerson app engineer came up with a great idea for the roll cutter. We were discussing all the forces needed to chop ( log saw - bologna cut - whatever your term may be ) and he suggested I investigate using a laser to cut the roll. Where can I find some info on industrial lasers? Is it more common to have 1 laser and use mirros / reflectors to adjust beams? I want to do the homework, but can someone point me to the library.
    jason
    motion guru's Avatar
    motion guru is offline Titanium
    Dec 2003
    Yacolt, WA
    2,931
    Do you have good fire insurance?
    Chris999 is offline Hot Rolled
    Feb 2005
    Vancouver B.C.
    709
    Correct me if I'm wrong, but you want to cut the entire roll in situ, this isn't a rewind/ slitting operation.
    Lasers cut with heat, and usually need to do so at a specific focus point, not good for trying to slit a thick section of something. Nevermind the tiny little drawback of igniting the entire roll of fabric.
    Even if it was a good idea, the cost is going to be on par with a waterjet system, which might work, but your CFO is going to burst several blood vessels when he sees the budget...
    Chris
    Mar 2006
    Los Angeles, CA.
    1,369
    okay, well noted. Somethings keep me up at night, the idea of a 20 inch blade rotating in my factory is one of them. I have more guards on the machines in place then Buckingham palace and still I worry.
    Jason
    3t3d is offline Titanium
    Nov 2004
    WI
    3,576
    I thought you were looking into ultrasonic driven blades.
    What happened to that?
    surplusjohn is offline Diamond
    Apr 2002
    Syracuse, NY USA
    8,868
    those spinning razor sharp, hollow ground discs are a concern. We had a worker by pass the interlock and ran his hand and forearm over one, you would not believe the amount of blood. serious cut and totally his fault.
    beyond that, I have used the baloney slicers allot and otherwise, with out incident
