Universal Machine Tending
Check out the VBX-160 a new Robotic CNC Machine Tending system at the International Manufacturing Technology Show (International Manufacturing Technology Show 2014). VersaBuilt will be exhibiting with ABB (N-6251) at IMTS in Chicago from September 8-13, 2014. I'd like to personally invite you to join us for a demo of the VBX-160.
The VersaBuilt VBX-160 represents a new category of machine tending products. The VBX-160 requires no robot programming, no robot teach pendant, no custom robot grippers and no special training of your staff. The VersaBuilt VBX-160 can tend virtually any part shape that can be held in a vise. Setting up a new part is as easy as setting up a new part to be machined in your CNC.
The Genius of the VersaBuilt VBX-160 is the patent-pending MultiGrip Soft Jaw system. Like ordinary vise soft jaws, MultiGrip soft jaws can easily be machined to hold a part in a CNC vise. But MultiGrip soft jaws are also engaged by the VBX-160's robot arm to pick a part from the shelf and transfer the part to the CNC vise for processing. The same soft jaws that hold the part in the CNC are used by the VBX-160 to transfer parts in and out of the CNC.
No week-long robotic training classes or expensive robotic engineering consultants. The VBX-160 is completely pre-programmed. A competent machinist can configure and setup a new part for tending within the first day of use. A VBX-160 is easily configured to run dozens of different parts. Typical job setup times are less than 15 minutes, including the time it takes to load the VBX-160 full of parts.
You can do this. We’ll show you how….
Please also visit our website at Versa Built .
