Just picked up a Schaublin 102TO from most likely the 1950's (sn# 110104). It has the back-geared headstock set up for the W20 collets, the 150mm compound and the "sightglass" style tailstock. If I read the info I found correctly, the headstock should be designed to operate up to 3000RPM.
I also got the grinding carriage, a twin post rapid feed production carriage, a 3 jaw chuck and a magnetic chuck (never saw one before). The motor is the original 380V, 1.5kw and it came with a transformer to step it up from 220V 3ph.
I swear there is more weight tied up in the electrical than the lathe itself. As I most likely will never use the grinding unit, is there any advantage to the original motor, other than the grinding pulley and integral mount? I am considering retrofitting it with a conventional motor to tidy things up.
I have a full size lathe for any heavy work, so this one will be for small jobs only, so should I consider going to a smaller <2hp motor? Considering your average 9" SB rarely needs over 1hp, it makes you think. Should I consider a VFD or a DC motor conversion with a speed control?
Your thoughts will be appreciated and I'm open to suggestions.
Mark
Mark
