Prototype
- Dec 2, 2002
- Victoria, BC, Canada
Hi,
I've got a bit of an oil leak from the the apron of my Graziano SAG14.
I think the leak from the seal for the feed rod but I'm not sure. The drip point seems to be from the drain plug but I sure the drain plug is well sealed.
Here is a link to a picture of this great lathe.
http://www.me.uvic.ca/~rbrougha/Graziano%20SAG14.jpg
I wonder if anyone out there with a Graziano has run into this problem and if such a leak can be repaired without a complete teardown of the apron section. I have a partial manual with parts identified with numbers but the description of the numbered parts is missing so I can't tell from the drawing if there are seals or packing that can be replaced or adjusted??
Ray
Ray
