Acciaio
- Apr 30, 2013
- Lucca, Italy
This thread is a follow on from 'VDF lathe information' I posted a few months back.
I finally found more or less what I said I was looking for in that last post: a VDF Boehringer 36s, located in Germany and at a bargain price, which I have now shipped back home (Lucca, Italy) and shoe-horned into my workshop. It is in fact a nominal 36 cm swing, but the relief in the bed at the headstock, added to the 355mm bed width, will allow for a 400mm faceplate to be mounted. Centre length is a generous 1000 mm (more like 1100). I reckon the year of manufacture to be around '64.
It is definitely a restoration project, since the machine has been idle for years and although not rusty, is well gummed up just about everywhere.
Positive signs are that the bed ways seem pretty good for their age, and the leadscrew also shows little wear.
The spindle seems fine (on a fist inspection, judgement reserved) and a look inside the headstock revealed clean and oily machinery. Backlash seen at the carriage handwheel is about 1.2 mm. Not sure about the cross-slide because it had been lubricated with grease and barely moved. This wasn't very promising, and after removing the oil-well cover on the saddle, it was plain to see that no fluid oil had passed that way in some time.... So off came the saddle (it wasn't that quick...), and the dried up wicks and saponified oil crud made it obvious that the apron needs to be removed and renovated. That is the next step.
One other issue, of an extremely annoying nature, is that the cross-slide crank got bent by the fork-lift operator while atempting to get the beast off the truck.... yes, the only words that came to mind at the time are unprintable.
I would appreciate any advice on straightening that without damage (heat.. i.e. stress relief?)
Needless to say I am looking for a manual... Kees, do you have one in your archives?? Pics are in the as-found condition in the seller's yard: more will follow.
