volzuki
- Dec 3, 2007
- Netherlands
I want to move my Graziano lathe to my new workshop, but it came without the leveling feet/bolts. There seem to be two versions of this, one with two holes: one for the leveling feet (just a bolt) one for the anchor bolts (unthreaded hole). Mine has the other option: only one hole (threaded) that accepts a bolt with a hole through which the anchoring bolt goes. I'm not sure if the threads on both options are the same. Because the threaded hole in the base is difficult to access and the thread looks a bit damaged, I'm not able to measure the threads myself.
Could someone on here measure their bolts and tell me what size they are so I can make my own and order the correct size tap to chase the threads?
Unfortunately the parts catalog only shows the part number and no further information
