kazlx
Hot Rolled
- Nov 22, 2010
- Tustin, CA
So I have a Cadillac 1440, which I love. From everything I've read, it's a Mori clone, so I figured I'd post in here. I'm not sure if the tail stocks are the same or not. There's the lock lever that locks the tail stock down on the ways, with the clamp on the bottom, like most lathes. This looks to use a cam setup and there is a roll pin that looks like it sheared (had been a little sloppy since I got it, now I know why) underneath. I was able to get the roll pin out, but now the cam action doesn't function via the lever. This is with the tail stock removed off of the lathe and upside down. I can probably just drive another roll pin in there and be on my merry way, but the lever has never felt all that smooth, so I want to take the action apart and clean, lube and possibly hone everything. Problem is, I can't figure out how to get it apart. No set screws, no obvious threads for unscrewing the main pin, nothing. Just wondering if anyone had insight onto how these actually come apart. Seems silly to ask about something seemingly so simple, but I've stared and stared and have no idea. I'm sure it's simple and probably right in front of me, but can't figure it out.
Thanks. I can add some pics if needed later tonight.
