Page 1 of 17 12311 ... LastLast
Results 1 to 20 of 326
Like Tree1Likes
Thread: My Cazeneuve hbx 360
    alb320 is offline Plastic
    Jan 2009
    Italy, Milan
    11
    Default My Cazeneuve hbx 360
    Hi guys,
    I have red all yours post about caz lathes.. very cool!
    I love Cazeneuve hbx 360, and now, I have bought it.
    But it has some little problem, I have to change all bearing of carriage and change water pomp because the original is broken.
    I have disassembled carriage, and I have found inside it a little of rust.
    Now, I have cleaned it, but I don't understand how the part in section "e" page 28 of user manual works. It look like a clutch with some side on his circonference for a lever. I have thought then the disks of "clutch" has to rotate regardless one to one, but all is blocket.
    I ask you some advices...
    Thank you!
    Attached Thumbnails Attached Thumbnails dsc00732-450-x-600-.jpg   img_0092-600-x-450-.jpg   img_0094-600-x-450-.jpg   img_0093-600-x-450-.jpg
    ole.steen's Avatar
    ole.steen is offline Cast Iron
    Jun 2002
    Oslo, Norway
    457
    Alb3320!
    Congratulations on your find! I hope you get it all sorted out.
    The stack of discs in projection "e" on page 28 is not a clutch, but a set of discs with slots, they are all fixed to the shaft they are on. The six discs have 1,2,4,6,10 and 14 notches respectively. A catch with a finger engages the slots, and is moveable sideways by pulling or pushing the rod with letters on the stem. When the finger engages a slot the big wormgear engaged with the leadscrew is locked, and the saddle is driven by the leadscrew pitch. It is all described on page 21.
    Ole
    Jan 2009
    Italy, Milan
    11
    Thank you Ole!!
    All is clear, now!
    I will make it running as soon as possible...
    I have broken the rod with letter... AGGGRRR!!! I have to order it....
    Alb320
    ole.steen's Avatar
    Jun 2002
    Oslo, Norway
    457
    Alb!
    It looks as you might have a leak in the variator hydraulics. This is common, and can rather easily be fixed by changing the seals, I can tell you how.
    Another common fault is leaking seals in the cover tubes over the leadscrew. The oil level in the apron depends on these seals, so if they leak a lot they need to be replaced.
    Ole
    Jan 2009
    Italy, Milan
    11
    Yes Ole, I have a leak in the variator... If you could say me how change the seals, I will be very grateful to you.
    And... I have to change all seals of cover tubes...
    Thank you
    Alb
    Jan 2009
    Italy, Milan
    11
    Hi guys,
    I need your help for disassemble variators of my hbx 360...
    I have tried it but I haven't done...
    How I have to do?
    Thank you..
    ole.steen's Avatar
    Jun 2002
    Oslo, Norway
    457
    Default hbx variator
    Alb!
    I realized I have lost some hi-res scans from the manual, I will get new copies later tonight. Until then:
    There are 3 seals to replace,one in the upper and two in the lower cylinder. You might just as well order them now, along with seals for the covertubes. If the belt is frayed or delaminated you need a new one.
    Do you have a slide hammer?
    You need one.
    Remove all hoses and the control linkage to the lower cylinder. Withdraw the valve body and rod. Mark the position of the spindle extension tube, as this determines spindle bearing preload. Remove the serrated lockwashers and the spindle extension tube. Remove the belt. Remove the little nut on the upper collector box.
    Tell me about your progress and skill level. Do you need me to be more or less detailed?
    To be continued.......
    Ole
    Jan 2009
    Italy, Milan
    11
    Thank you Ole! Your guide is preciuous!!
    I have done your tutorial!
    I have removed valve of bottom variator, and I have removed all in your giude but upper box would not come out... I can rotate it but I can not remove it... it seems locked.
    Thank you a LOT!
    Jan 2009
    Italy, Milan
    11
    I haven't slidehummer, but I this extractor, can I use this?
    ole.steen's Avatar
    Jun 2002
    Oslo, Norway
    457
    You can try with the gear puller, but be careful! The threaded part where the nut came off is very thin, M6? You may try to protect it with a long nut or maybe two nuts on top of each other, so the extractor does not ride on the end of the spindle.
    I used a slidehammer like the one in the picture, it was not more than 15 euros at an auto tool shop. Take out the screw from the gear puller, connect the slidehammer instead with a bolt, fasten the claws around the housing and hammer it off. Take care so it does not drop too far, it is a thinwalled aluminium casting.
    Ole
  11. #11
    ole.steen's Avatar
    Jun 2002
    Oslo, Norway
    457
    Alb:
    Here are the scans I promised:
    When you have pulled off the collector box, remove the big nut, and the outer sheave half may be removed from its cone with a puller fastened to the threaded holes. Don't pull on the rim of the sheave, it will distort!Replace the seal, and polish the inside of the cylinder if there is rust or wear.
    On the lower unit the nut should be readily visible when you have withdawn the valve cover and stem. Remove the nut and withdraw the cylinder.
    You now need to pull out the pin running in the slot inside the cylider, connecting the outer sheave and valve slide. The pin has a thread (M4?) to facilitate removal. Fasten the connector for the slide hammer to the pin with a (strong) M4 screw, and pull the pin just enough to enable removal of the sheave. Replace seals as on the upper unit, and reassemble. Adjust the linkage and the upper sheave brake according to instructions in manual. Good luck!
    Ole
  12. #12
    K Battenbough is online now Aluminum
    Aug 2005
    Baghdad for now, then Wales
    239
    A couple of Qs Ole.... what did you replace your seals with? factory supplied seals or from another source? and lastly did the lathe get any quieter when they were replaced? Ive yet to get around to replacing mine, but im contemplating using a servo motor instead.
    Many thanks.
    KB
  13. #13
    ole.steen's Avatar
    Jun 2002
    Oslo, Norway
    457
    Kev!
    No, the noise stays the same, I guess. (I have only run it for some seconds with the old seals, as oil was pouring out.) I found off- the shelf polyurethane hydraulic piston seals that fit, but it was a long search. I paid around £ 25 each. Ordering from the factory would have been easier.
    If you are considering changing to a VFD motor you should look at JHOLLAND1's posts about his conversion. There is far more work involved than changing the 3 seals. With the variator working in the original configuration the HBX has excellent ergonomy and is a joy to use, maybe except the noise. My supplier says that current polyurethane seals are much more durable than the ones they made in the 70-ies, and should last another 40 years.
    Ole
  14. #14
    Jan 2009
    Italy, Milan
    11
    Thank you Ole!!
    I have done it!
    I have removed both of variators, and I have to order new seals, now!
    I'm very grateful to you for your advices!
    Thank you!
    Ps: I will post my progress as soon as possible.
    Alb320
  15. #15
    ole.steen's Avatar
    Jun 2002
    Oslo, Norway
    457
    alb!
    Well done! Don't hesitate to ask if you run into more problems.
    Ole
  16. #16
    GM's Avatar
    GM
    GM is offline Cast Iron
    Sep 2004
    Californias Central Coast
    376
    Hello Ole, I want to thank you for this post. Your very well detailed description has given me more confidence to tackle this same job on my hby590. Things are slowing down and I've been meaning to do this job for some time now.
    Thanks again,
    Gary M.
  17. #17
    Aug 2005
    239
    Hey GM
    Make sure you post some pics of your progress, I too will be doing the same in the future.
    KB
  18. #18
    ducbertus's Avatar
    ducbertus is offline Cast Iron
    Sep 2007
    netherlands
    270
    Hi guys,
    I'm here as I got my HBX360 last Saturday. the previous owner changed the oil and the oil-filter. He attended me about the massive oil leak at the lower pulley area.
    a member of this forum (yoyo) close to my residence sended me the manual posted by Ole Steen.
    reading the posts, I think I'll replace all the seals of the variators and the tubes.
    So, probably I'll need you guys soon for advise.
    Ducbertus
  19. #19
    ole.steen's Avatar
    Jun 2002
    Oslo, Norway
    457
    Ducbertus!
    Go ahead, I'm with you all the way!
    Ole
  20. #20
    TNB
    TNB is offline Hot Rolled
    Aug 2002
    FRANCE
    993
    Question
    Quote Originally Posted by ole.steen View Post
    Kev!
    One thing I've always wondered about HBX lathes :
    The leaks seem to be a common problem. How is it that nobody ever came out with a mechanical alternative for the hydraulic actuator ?
    It would probably be pretty easy to actuate the expanding pulley with a mechanical device such as a modified speed reducer or something similar.
    That way, it may be possible to get rid of the hydraulic pump and to replace it with a smaller and quieter unit for the sole headstock lubrication (I seem to recall most of the noise is generated by the hydraulic pump ?).
    Do I miss something ?
