Hello,
I'm in the process of buying a Schaublin 102-VM and have found two machines that look promising. The machines are from the same year and look to have about the same wear. The W25 version have more change wheels and an extra chuck, other then that they have similar tooling. The W25 is slightly more expensive.
I can't make up my mind what to buy. I have an Aciera F3 so the same collet is apealing, the W20 is also located closer and easier to transport. But my gut tells me that I'll regret not choosing the W25 version. Is there any other benefit to either of the machines that I should consider?
I've yet to go and measure on the machines, the result of that might be the deciding factor.
Best regards
Best regards
