Im starting to loose speeds on it and I was told that the clutches are starting to go.
And im told its pretty expensive to replace those clutches.
A local machinery dealer who use to sell Graziano lathes told me that a reason that the clutches start to slip or go bad is that the oil in the gearbox after time starts collecting metal particals, with enough metal dust in the oil it acts as a conduit and ruins the clutches. He said oil has to be changed often. Just passing on some info.
SAG 180,
In case you weren't aware, the Sag 12 gearbox is nothing like the other Graziano models. It uses magnetic clutches to change speeds and direction. No adjustments possible. However, as you say, clutch parts are available, and Gizmo Wizard has posted excellent info on how to overhaul these gearboxes. It certainly helped relieve my fears of what to do when my gearbox starts to play up.
Sometimes my lathe doesn't reverse correctly, but I will check the switching before I worry about the clutches, maybe try powering the clutches directly to rule out the possibility of switch failure?
As a longtime SAG 12 user (and owner) I have repaired and rebuilt several gearboxes over the years. I bought out RAM- SAG's remaining SAG 12 inventory when they finally closed up a few years ago. I have some new clutches from a different model that could probably be adapted to the 12 gearbox, but haven't had the time to work out the details.
In any case, I have rebuilt the original clutches and it was a whole lot cheaper than buying new ones (about $1200 each at the time). It requires making a spindle to wind the wire (I Believe it was 1mm thick copper) to a dimension that fits inside the clutch housing. The approximate resistance should be about 12.5 ohms for the winding. after installing the coil and connecting the wire ends, seal it up with a marine grade epoxy that is impervious to oil, let it set up and re assemble the gearbox. I did the labor myself and had an electric motor repair service do the epoxy job but he would not tell me who made the epoxy (big secret I guess). I'm sure that could be sourced out very easily today. I will be doing this again to my latest machine as soon as I can afford to have it down for awhile as I lost the 1250 rpm speed. I will post more info as find out.
BTW, a preventive measure is to turn off the main power switch when the machine is in use. Even with the motor turned off the clutch on the selected speed is still energized which is why the clutch for the most commonly used speed burns out. I hope this has been helpful.
Bill
Notice
