For Schaublin 70's with roller element bearings, the manual recommends cleaning and re-lubing the headstock bearings periodically (every 5 years) and gives instruction on disassembly.
Removal of spindle shaft is quite easy following their detailed directions, the last of which is "then remove the bearings" As the shaft came its not clear to me how to do so.
Here's the spindle - anyone know how to remove the bearings?
On the inboard side, the outer race is left in the headstock. Does this come out (for cleaning, as part the PM?
Outboard, how is this bearing removed? as its against a shoulder, there is no way to press on it from the other side except on the inner race
