jlakes85
- Sep 10, 2011
- Northern NJ
I just completed wiring up everything for my recently acquired Voest DA series lathe. I am having an issue where sometimes I will be able to run the lathe through all speeds, but other times the lathe motor will not start in any speed setting. I am assuming there is an issue with the relay between the incoming shop power to the panel and the main motor. Has anyone experienced a similar type of problem. This is a circa 1980's lathe. Could there also be an issue with some sort of safety interlocking device to prevent crashing the gear train? Also, does anyone have a manual for sale for this lathe?
jlakes85
jlakes85
