Weiler LZ330 Feedbox transmission
nick gill
Dec 23, 2016
How to switch between belt and gear drive?
Your lathe is different than mine so I'm not sure. I'll take a photo of mine when I get home so you can see the difference.
Sent from my SAMSUNG-SM-N910A using Tapatalk
The lever on the far left of the first photo moves a plate that engages either the belt or gears.
Swing the two large gears back and up, out of the way. (19mm wrench)
Pull the double pinion gear off the lower stud (It is retain by ball detents)
Pry off the retaining clip on that secures the stud gear that remains after pulling off the double pinion gear.
Move that stud gear to the keyed shaft that also mounts the belt drive pulley. This gear will now engage with the dark fiber gear, LINE UP THE TEETH! Install the retaining clip.
Shift the lever in the headstock to disengage the gear drive (handle on the left of the chuck key.
My description might be off, but I just did the change over on my own LZ330, so I know what I tried to say works! ;-)
Enjoy a very sweet machine.
