Swing the two large gears back and up, out of the way. (19mm wrench)
Pull the double pinion gear off the lower stud (It is retain by ball detents)
Pry off the retaining clip on that secures the stud gear that remains after pulling off the double pinion gear.
Move that stud gear to the keyed shaft that also mounts the belt drive pulley. This gear will now engage with the dark fiber gear, LINE UP THE TEETH! Install the retaining clip.
Shift the lever in the headstock to disengage the gear drive (handle on the left of the chuck key.
My description might be off, but I just did the change over on my own LZ330, so I know what I tried to say works! ;-)
