Weiler LZ330 Feedbox transmission
Community On The Web
Results 1 to 6 of 6
    Dec 2016
    NEW ZEALAND
    8
    Default Weiler LZ330 Feedbox transmission
    How to switch between belt and gear drive?
    Mar 2016
    35
    18
    Your lathe is different than mine so I'm not sure. I'll take a photo of mine when I get home so you can see the difference.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    Mar 2016
    35
    18
    Dec 2016
    NEW ZEALAND
    8
    So different!
    How do you switch between belt and gears?
    Mar 2016
    35
    18
    The lever on the far left of the first photo moves a plate that engages either the belt or gears.
    Dec 2008
    Vt USA
    5,497
    442
    1570
    Quote Originally Posted by nick gill View Post
    Swing the two large gears back and up, out of the way. (19mm wrench)
    Pull the double pinion gear off the lower stud (It is retain by ball detents)
    Pry off the retaining clip on that secures the stud gear that remains after pulling off the double pinion gear.
    Move that stud gear to the keyed shaft that also mounts the belt drive pulley. This gear will now engage with the dark fiber gear, LINE UP THE TEETH! Install the retaining clip.
    Shift the lever in the headstock to disengage the gear drive (handle on the left of the chuck key.
    My description might be off, but I just did the change over on my own LZ330, so I know what I tried to say works! ;-)
    Enjoy a very sweet machine.
