I have done some research on change managers and am wondering if anyone has any experience in hiring one and what the outcome was.
I am the minority owner of a business and frankly over the last few years our business has evolved into something I don't like. I feel like the "boy who screamed wolf" anymore and am wondering if I brought in a professional to analyze our operations maybe I can get some movement and implement needed changes. Or maybe they recommend removing me, at this point that's OK too. lol
Please share if you have any experience with this type of program.
I have lived through several of these types of events.
First problem I see is that there are some really talented change managers out there that can do what they claim but there are tons more that know all of the buzz words, make big promises, and no matter what, get to walk away from the disaster that they create much richer and unscathed. The trick is to sort out the gems from the dirt.
Remember, an expert is someone that is 50 miles away from home.
I often see a pattern that an organization has problems but not sure how to fix them. Hire an expert for large dollars, expert makes lots of expensive changes that have little effect, owners tire of wasted dollars and time, fire expert. Owners then start a new search using the same search criteria. Rinse and repeat. Troops end up demoralized with the most talented leaving. Usually the causation agents remain making the overall problem worse.
I think Pogo summed it quite well. "We have met the enemy and he is Us."
In your specific situation, since you are a minority owner, you are at a strategic disadvantage. I suspect that you hope by bringing in a change agent, that will force the majority ownership to move in a direction that you desire.
If the current majority ownership is satisfied with where the company is at, there is very likely no desire to change anything that will cause discomfort.
Without knowing the situation details and from what you have stated that you wouldn't mind leaving if things don't improve, I think the most likely strategy for you is how to exit the company with the maximum amount of money.
If you see things now that you can't get changed, it is not very probable that you will get a change manager to pull this off. You will probably end up compromising on who gets hired as the change agent, nothing will change for the better, and cash that you could grab today will be gone.
Now if
ALL of the principles can agree with the need for change, the direction that
ALL of you want to go, and are extremely committed to the end goal, you have then have a reasonable chance of success. Any less, don't go there at all.
One common problem I have seen is that top management often is lacking some core management skills that are the real underlying problem. The troops know what the problem is but are powerless while upper management is busy re-arranging the deck chairs on the Titanic. The expert's answer is to hire me and I will make a new placement chart for the deck chairs, use the life boats for a bonfire in celebrating the new chart, and busy the crew with polishing the deck chairs.
Unfortunately, the expert sails away in his reserved life boat and everyone else is left to survive on their own.
As you can tell, I'm not real excited about this approach. I view it as whoever it is that is in charge as a manager, needs to know his strengths and weaknesses. He needs to hire or improve the weak areas and play to their strengths. If you don't know what you can and can't do really well, then you need to start there. After that you might actually need to hire a specific person to fill in around your weaknesses or just might need someone to show you how.
You already know that you don't like the current direction and you already know your organization. The expert will spend at least 4-6 months figuring out where you are today. Any changes before then will be for just changes sake with little real purpose.
I wish you luck.
