If you can find some other place to go ,,,,, RUN , , , ,. I went from doing tool & die work/ fabricating to working in a hydraulic shop full of gorillas and people they dragged in off the street stood in front of a lathe and showed them just enough to make it go.I do my best to teach proper tool use and setups , speeds feeds and maintenance . Ive been bullied lied to constantly belittled and even fired. 3 fellow employees have made blatant attempts to get me fired. And now they have the management convinced that im the problem. They use the words Common denominator , This is the only place ive ever worked that ignoring the jokesters and bullies hasn't stopped them. Be careful when pointing out bullying , have 100% proof positive . or they will turn it around and make it your fault. I pointed out to a foreman that one of the gorillas was constantly crashing into the lathe chuck , "YOU NEED TO WORRY ABOUT YOUR JOB AND WHAT YOUR DOING AND NOT ABOUT HIM " and nothing was done. I have nowhere with in an hours drive that isn't a Poohole worse than where I am now. So like I said RUN if you have anywhere else you can go.
