Sounds like a good 40hp RPC min should doo the trick for you at this stage. A 50 would allow some growth room. You don't really hafta worry about "overloading" the RPC. You aint gunna hurt it at all. If you "overload" it will simply mean that you may not git quite the hydro on L3 as you would have.
The more induction motors that you have on the circuit [running] the more help you have at balancing things out. This does NOT seem to be the case on the CNC's.
I [normally] have a real nice 60hp "Phasemaster" that is built on a Lincoln frame. I love it! OK - so some caps finally took a dive after 12 yrs of service - mostly 24/7.
The 50hp I have running right now won't start my 50hp lathe in high gear. So I guess I doo need the 60.
(I usta run a 50 AND a 60!)
With that unit I could power everthing in my shop that I wanted - including up to 50hp CNC lathes. Only the one machine was too finicky for the situation - and as I noted before - it seems to have been an issue when it was on the grid as well.
The only time that I have a real issue is when starting a bigger induction motor. The quick in-rush would kill some CNC's. I don't know if this is ever an issue on grid power or not? I would think the closer you got to max entrance KVA (transformer/cable size/distance) that the grid guys sould have issues too? I would like to hear on that...
I have noticed that my 10hp air comp will mess up some machines a bit now and then. Also - if I was to run a big Acme (20hp) these last so many yrs (seldom it seems) I would go around and put the CNC's in feed hold and then go start it, and then come back and hit the cycle start buttons. Kind of a pain, but as long as I wasn't starting/stopping all day long it was fine.
I finally installed a "soft start" on an Acme a few months ago so that I could run a busy job on it. I fired it up many times in a three day period and never had a CNC fault out at all! I am a happy machinist!
Thinking about maybe puting one on the A/C, but generally I jist let it run on continuous.
If you can't find a deal on a used RPC, and hafta buy new, I would check seriously into the PP tho. They say that the new ones are "add-on" friendly, so if you git what'chew need now - you won't be out in the cold once you outgrow it b/c you can jist add another 20 on to it. With that said tho - I hear/tell that you can stack RPC's too? I've never done it.
