Wifey tried telling me that I wasn't quoting high enough and that I am "out of touch" with what things cost today. (Not so much today _ today, but last yr when there wasn't two nickles to be seen at the same time to rub together.)
So I asked her to go through and tell me what had changed drastically in the last few yrs - overhead wise....
So she went down the list...
Turns out that hydro has went up maybe 15% in the last 20 yrs, Heating may have went up a bit in the last yr, but in the last 5? Most everything else had stayed the same, and it almost seems like something had fallen a slight bit. ??? Shirley interest rates have tanked, and that can be a diff of 4 digits a month! So - IMO - per whatever unit you like to use - If you take emotion out of the equassion and actually doo a cost comparison - overall - I'd say that biziness is at the very least the same as before. Depending on your version of before.
How far a red cent goes once you git home may be a nother story, but around here (geographic area - not "my shop") - payroll is less now than it was 10+ yrs ago for sure! So to say that you (I) need to make more $/hr is only right if that is what it takes to compete for labor in your area, or what it would take to entice you to leave your shop and go to werk for The Man.
Yes - materials are up. Fuel to deliver those parts is up. Don't forget tho to figger in the diff in fuel milage that you git now as compared to the timeline you want to compare to... Tooling may cost more. Maybe not? But does it cost more per finished goods out the door? I doubt it.
Otherwise?
Make sure when you are looking at the numbers that you relate it to "per unit". If you moved to a nother building and got more space, better electric, nicer looks, and better visibility, I'm not sure that you can say that costs have went up, you may have just decided to spend more. Those added costs could be justified under "sales" and "employee retention" more logically. (just a fer-instance, I have no idea of your situation)
Hate to ruin a good subject with logic...
Ox
I am not actually moving to Ohio- but it sure sounds like a different planet than the one I live on.
Around here, EVERYTHING IS UP.
My utilities have all steadily gone up- not just electricity, but propane that I use for some heating and forging has almost doubled lately. My minimum on my water bill and my garbage bill have both gone up in the last year. My phone bill is up. My internet service costs more.
Yup, my fuel is more- and I have had the same truck since 2003, so no big changes in mpg has helped that.
Plus, if I send anything by FED-Ex, UPS, or common carrier, all of those costs have gone up a LOT.
Materials are, in some cases, double what they used to be. I just got quoted $15 plus a pound for some bronze I will be needing, stainless, which I use a lot of, is about DOUBLE what it was five years ago.
But consumables are way up to- cause of that explosion, acetylene is way up, but normal welding gases are up, sandpaper creeps up, drill bits cost more- basically everything my machines and processes consume costs more.
In ours state, wages are always creeping up- we have the highest minimum wage in the nation, its about $8.75, which means no floor sweeper worth hiring is under ten bucks, and decent shop help is more. It hasnt gone down.
My real estate taxes went up again this year, even though, if I sold, the place is worth less than it was a few years ago. Sales tax went up.
My own power costs are all up- virtually every food and drink item I dont grow myself (which is a fair amount) had gone up a LOT lately. My Carhartts cost more. Leather gloves are a couple bucks more a pair.
Frankly, I cant think of anything I use in the making of products that is cheaper now than it was five years ago, and most things are 20% or so higher. Some, much more.
I guess Blue Ray players are cheaper- but I dont have one, and dont use one to make stuff. All the things I DO use are more, and more, and more, it seems.
Even my damn kids grew, and now need more expensive supplies.
