Friends, I am planning something surprising, shocking, stupid maybe. It’s about a conventional machine tool, namely a double end lathe. Such an apparatus has a number of possibilities over the well-known asymmetrical lathe.
I have a mate who has a shop and needs work. Now, I am more the thinker while he is clearly the doer. Not that I am not capable of making chips and burrs, it’s also more the situation of mine inasmuch that I’m having time which he isn’t. The idea has been swirling around in my head for a year or two now. Of course did I do some research on the subject and as the situation presents itself there are only very few if not one single maker, namely in the empire of the middle.
A double-end lathe basically has a central, rather short, spindle with some means to clamp pieces and two carriages to both ends. Once a piece is set into rotation one can give both ends of it a flat face, a center, and so on. More or less symmetrical pieces are thus very quickly prepared for subsequent operations between centers, in one setup. Centers are very well in line with each other. From a little delibaration one understands that it is wiser to move two tools parallel from the machinist’s point of view, not in opposite directions. One would employ a RH and a LH center drill for that reason, a right and a left turning tool. There’s worse.
So here’s what I’d like to know from the sage and wise forum: Do you see a chance for a medium size product of that kind? Do you believe it could have a chance when being of a conventional concept with possibly mechanical feeds, say swappable cams? What if I’d aim at a heavy old-time cast iron layout, preferably heavier than today’s fashion, actually a long lasting product made to be easily maintained? I’m thinking of a two-inch spindle through right now.
